MonsterMark
JP mentioned on another board that he was 1-1/2 mph shy on his trap speed in the 1/4 mile. I've been playing with crank vents recently on a Nascar dyno and we found 4 hp the Nascar boys could never find. We had 40 guys packed into a little dyno room for the test. If you never heard a Nascar motor wind up to 9100 rpm's, let me tell you, it is deafening. And what was truly unbelievable is these motors, running up the rpms from 3000 to 9000 rpm never even quiver. A glass of water wouldn't even rippel the surface....with NO engine mounts, just a cradle. Fantastic!
In the end, one of the guys thought it might be good for as much as 10 hp on a worn motor, or 6-8 hp on a 'dart' type block. The negative pressure in the crank sucks the rings out and makes them seal alot better. I am playing with them on my Mark right now. I pulled soo much negative pressure the motor was wheezing thru the front crank seal. Unscrewing the oil cap was unreal. Pooof. Tons of suction. I would say almost as much as a wetvac. 2 vents (one in each valve cover) created so much negative pressure in the crank that it scared me. I need to get a read on oil pressure and A/F before I go further. However, the initial 'seat of the pants' felt like there was a good 6-8 hp there. Should have some dyno numbers next week after some Xcal2 tweaking. Might be the answer JP is looking for in the quarter. I get my GTech Pro SS in a couple of days so I will at least get a 'close' read on Hp and Tq numbers before the dyno session. Plus, these puppies are easy to install. I am working on a kit if things pan out.
