ONLYTONY
Is there a way to repair a door panel on a 95 that shrunk a little. I'm thinking a heat gun and some clamps. If I push on it with my knee it goes into place but does'nt stay there. Thanks TONYyyy
With that color, fill in the gap with peanut butter.
Not sure but I have to do the same with mine, haven't been able to find a new panel or a good used one to save my life so ill have to repair mine..the top is separated too which needs to be reglued.
I'll be watching this thread, because mine looks just like that.
Yeah but that's the wrong color combo, mine is like onlytonys..it has that dark charcoal top part, the one in the eBay ad has tan on the top..wouldn't match.
Did mine a few years ago, but used clothespins to hold it. Used auto trim adhesive, it's starting to creep out some, maybe try gorilla glue next time.
C Clamps with wood backing might work better, it's a thick area.
Can I use chunky PB? If you glue it what's going to happen if you have to get to the switches? I plan on heating it slowly,clamp it to get it back to orginal shape. Might take a few times. Maybe expoxy plastic strip inside to maintain shape.![]()
Use Peter Pan but without chunks.Heat would help you shape it and if epoxied in place or glued, you would still be able to remove your switches. They would be removed anyway while you do the fix. Epoxy adhesive is what I would try first. I think it would hold.
I've had better results with Jiffy and a hint of honey. But to each their own.
Kevin, that piece can be removed and replaced with what you have already. I personally would remove it and paint it like you want it, let it dry and then replace. All of that trim can be removed. It takes work and time but it can be done.
