98lincmk7lsc
Differences between gen 1 and gen 2 door handles?
Do they interchange at all?
Thanks
Thanks
yes, they do, 1st gen's are thinner and have a bolted on counter weight, 2nd gens are thicker and have a molded counter weight. 2nd gen are stronger by far.
I think it is supposed to ease opening or reduce rattles... I'd leave it off...
if anyone has a 97 or 98 with a bolted counter weight that means its been replaced and with a 1st gen handle!!! only 1st gens had bolted counter weights, late 96, all 97 and all 98 had a molded weight, the handle is different too, a first gen handle is thin and flat, the second gens are slighty contoured and alot thicker.
if you are calling them thick, then you have not held a real 2nd gen handle in your hand, never was a 2nd gen handle made with a bolted on counter weight. and yes the chrome 2nd gen inside handles will work in a 1st gen mark. i sell the chrome inners all the time.
