I know what your sayin Tommy.
Myco said he had the coolent system pressure tested too.
If he had a leak somewere it should have been found during the pressure test.
That includes a head gasket.
how much pressure do you think the "test" the cooling system with?
15-20PSI?
that's ALONG way from 160-180PSI that you find inside the combustion chamber.
like I said, 15ish lbs might not be enough to open the leak, where 160-180LBS PSI inside the combustion chamber could very well expose a cracked head, cylinder or headgasket.
