Alright, I'm going to try just one last time.
Quit :q:q:q:qing around with the fan, and try to figure out what's wrong with your engine!
What caused your cats to clog?
The picture of the hole in the piston indicates detonation, possibly caused by a lean A/F mixture.
Not overheating at idle, but overheating while driving also indicates a lean cruise problem.
Have you pulled any DTC's?
Based upon what you've posted here, I'd suspect one of the following:
Bad fuel pump
Clogged fuel filter
Kinked fuel lines
Bad injector(s)
Bad O2 sensors
Bad tune
Bad PCM
The only way to know for sure is a Wideband O2 and some datalogging.
Since you don't have any serious mods, the first thing I'd suggest that you do is stop using the Sniper and return the car to the stock tune.
Is your car even running right now?
