kustomizingkid
I will be doing mine the exact same way as Mespock and Driller, with a huge filter that K&N uses on their one of their Turbo deisel kits.
FYI, the biggest filter I could fit in there(with the air suspension compressor lowered) was a K&N RU-3480 which is 6" long, 5-7/8" bottom diameter, 5" end diameter and 4-1/2" flange ID. Without the compressor, you could use a larger filter.
I've ran a K&N filter for about 7000 miles on my diesel. Oil analysis came back with quite a bit of dirt in the oil. IIRC it was sitting right around 7. The K&N Filter didn't filter the air properly on that motor. I switched to an AirRaid setup, and now my dirt in oil levels are sitting at about 2. The average with an OEM filter is 5.
I've used K&N Filters on my cars, too, but frankly, I haven't seeen any performance out of them.
What people don't seem to understand is that a high flow air filter can actually hurt your cars' WOT performance. The computer doesn't read sensors like the O2's, MAF, and some others when you're under WOT. The computer can't do the math and adjust fuel mixture fast enough.
Under WOT throttle, the computer bases it's ignition and timing on built-in tables. Tables that were set up with an OEM paper filter. So, we have more air going into the motor with the K&N Filter, but the computer doesn't know this because it doesn't read the MAF when under WOT operation, but rather looks at it's built in tables, and says: "Ok, we've got this altitude, I'm running x RPM's, so I should be getting y lbs per minute going into the motor. According to my fancy doodah table here, I should be injecting z ammount of fuel into the engine in order to keep the correct stoichometric ratio."
Since the computer is not accounting for the extra air that goes into the motor, guess what happens when you don't have the proper fuel amount going into the motor? Anyone? Anyone? Bueller?
Granted, chances of you grenading your motor are very slim, but you know what? I don't like my motors running lean, no matter how miniscule that chance is.
At least that’s how it was explained to me by a leprechaun in a forest once...
Yes, I know this. I’m talking STOCK. Even so, ask your tuner if he knows how many pounds of air your K&N filter flows at say, 6000 rpm. If he knows, then great. If he doesn’t know, how will he know what table changes are required with new numbers when he does your tune?
