m_maker
Again there is nothing I repeat nothing with the intake manifold volume that will effect idle, period. If the idle is fluctuating its a vacuum leak, IAC, timing ect. not manifold volume. I run a cobra intake with a 1/4 inch hat spacer 1" throttle body spacer and split cut back runners and have mine set lower then the stock gen2 intake, and even with the stage two cams I can get the idle rock solid at 700RPM.
PS and have no problem with timing or fuel curves.
+1
7 swaps and counting, no issues whatsever without touching the volume parameter.
Put the stock tune back in the car, it will idle fine. It's probably the sniper gizmo
