So I finally got the C&L intake tube, had to extend the IAT wiring, the problem now is my 9 inch conical is too big and will not fit... it's always something ain't it? Well I fired up the car and it runs, the car doesn't idle that great, the idle wanders from 750 to up to 1000rpm, got a CEL for IMRC'S... uploaded my tune with the IMRC and EGR delete, no more CEL but the idle is still rough... datalogged it and the idle timing was only at 1-2 degrees of timing! With the stock intake and IMRC's it was at 10 degrees on the stock tune and 15-18 degrees on the Sniper NA tune. I added two degrees of global timing and it now reads at 4 degrees, still too low im thinking... also i'm thinking the Cobra tps needs to be calibrated? I drove it down the street real quick and holy crap the throttle response is so much better and snappy... whoever says the swap is not worth it on an NA motor is seriously wrong...
Full swap consists of:
Polished cobra intake manifold
MMR IMRC deletes
Cobra fuel rail with Vortech fuel lines and Kirban adjustable fuel pressure regulator (fuel pressure set to 48psi)
C&L intake tube
MMR IMRC deletes
C&L intake tube
