CHASSIS HELP... quick question
Long_Island_LS
Long Island
ok quick question guys...need some advice - im gonna overhaul the chassis on my 02 LS V8 with 90,000 - its got some clunks here and there... im definitely gonna do the lower ball joints, and probably the inner and outer tie rods... i work at CarQuest so the parts are really cheap and once i do this i wanna be set for another 90,000 miles...anything else i should do?... im gonna crawl under there and n see if anything else is obvious... but is there anything else i should do just for the hell of it before it gets cold?? i appreciate any help...thanks
...and o yea...i already did the front sway bar bushings and plan to do the rear as well...
are you buying just the ball joints and putting them in or are you buying a whole new arm?
