lsc 98 f100
any one have any information about a cb radio with no antenna at all? i want a cb in my mark but i dont want anything sticking off the top of it. do they even make such a thing?
I though c.b. radios went out in the early 80's
Trucks still use them and they are always pointing out cops. Plus it's easier to use than a cell.
You don't necessarily need an externally mounted antenna for communications radios..
A CB radio in a Mark VIII? Is this said Mark going to be on the HWY all the time speeding and "depending" on truckers to tell you about cops? If you're going to ruin it, go all the way. Cut a hole in the trunk, dead center and install the 10' antenna with a tennis ball on the top. The "Bandit" in a Mark VIII. Next you can put the gold eagle on the hood.
No, truckers and rednecks still use them.
You forgot the T top Terry
or you could get a Lincoln Mark V with the CB already built in
You do if you want range, and frequency pick-up. Without one you would not get any emergency channels nor someone calling out a few miles out.
Try using a scanner without a external antenna, you get nothing without a antenna.
If really serious, I would recommend looking into one of the higher quality ham radio hand held units that can transmit/receive a wide spectrum. From what I understand, one can get into the entry level of ham radio nowadays fairly easily. No morse code tests or anything like that for a beginner.
