can I use these
The offset is wrong...
Somebody may need to correct me but you would want a 30 on the front and 40 on the rear for a 9/10" wheel setup.
Offsets will work just fine.
The 10" rear wheel may rub if the suspension is under compression.
A 295/30-20 is about a 1/2 inch wider and 1/10 of an inch taller than my 285/35-19s and it will be pushed 3mm closer to the fender than my 19x10 48mm offsets.
I would not have had to roll my fenders if I had put my Cobra Bilsteins in first, it doesn't even come close to rubbing after the roll and shocks.
-Alan
+1 on the should clear vote.
Makes a hub swap a must as the mustang wheel choices explode.
More Here
I thought that 98lincmk7lsc's setup was 30mm and 40mm, I always kept his in mind for when I picked wheels. I hope maybe he'll come in here and clarify.
Click!
Nice, 20s are a bit much for my taste.. but I wouldn't mind those
We really need a wheel sticky with pics!
Wheel size, offset, tire size, suspension mods, fender roll, and bolt pattern. ( year and car they came off of if factory)
I agree a sticky never hurts, I have listed all the specs for mine in previous threads but will be happy to do so again if someone will create it.
-Alan
