dRock95MarkVIII
Hey everyone, got a question -
My Mark has been wonderful, however out of no where there was a buzzing/rattle type sound from the back of right front wheel area when I started it about an hour ago tonight.
This is the first time the noise has appeared, and semingly for no reason at all.
THe noise is only present in Park and Neutral, no noise in gear.
The noise gets much quieter, and eventually is gone at idle as the engine/fluids/exhaust warms up. However it will make the sound again if I blip the throttle (again, P/N only)
I'm pretty well-versed in panther platform tech, so my first thought was heat shields on the cats buzzing/rattling. My Mark is so damn low there was no way for me to check them out or look tonight, but I will probably put some hose clamps around them just in case to rule them out.
I've heard a buzz from the valve body can occur on the -95s - I'm not sure if this is what I have. It occurs only in park and neutral, gets quieter when warm and car operates flawlessly. The buzz is not very consistent, goes in and out and sounds VERY tinny. The buzz matches engine RPMs, however, once the car warms up just a little bit it only occurs when the throttle is being pressed (meaning, if I rev the engine up I will hear the buzz match RPMs, but the second I release the throttle the noise is gone - even if the engine RPMs have not dropped fast enough yet)
Is it normal for the valve body buzz to appear out of no where? The car was dead silent just yesterday - the noise *just* started today.
Any thoughts would be much appreciated
