Breaks Grinding?
M4rk
Ontario
Hey mens,
I have been hearing some grinding noice coming from my breaks when I break at a stop light and stuff. I took the rim off and took a picture:
Halp?
Yes, I think that those brakes are broken.
Where did the picture actually come from?
The breaks look fine to me. Just replace all 8 coils and plug wires and youre set!
Probably a DCCV problem. Are you getting heat out of all your vents?
should be able to get one more turn out of those before your outa spec....
I had won similar to that i pulled of a car years ago... unbelievable
Mark, sometimes bent sliding pins will cause that. I would just replace them.
If that doesn't fix it, it's most likely the vent tube on the battery.
When I worked at a shop in highschool we got this Grand Cherokee in on a flatbed with a "bad oil leak." The problem was that the oil filter had rusted though.
unbelievable....
oh snap you got the new stay cool rotors. the pad just slides into the grooves and stops the car. Thus keeping all parts cool.
