Braking Issues
GMAN
Spring, Texas, United States
I'm noticing some braking issues lately. When I had the regular Mark brakes on, I would notice that I cannot get the brakes to lock up. I could slam on the brakes with both feet, and I could not get the nose of the car to dip. The car would just slow down gradually. So I swapped out the master cylinder, and still the same thing. I swapped out the brake booster, and it's still not any better. So I upgraded to Cobra brakes with 13 " rotors. Although I can notice the difference a bit, I can feel the new pads biting, It's not biting like I think it should. I can still slam on the brakes and I can't get the brakes to lock up. I can barely get the ABS to activate. One time I was driving home and I was passing up a car that was driving to slow. I go over into the right lane to make a turn, and I depressed the brake to make the turn, and I didn't feel the brake bite at all. I had to do a hard turn onto my street. Then I stopped. If noticed that a lot lately. I can press the brake once and the brake isn't stopping the car. I take my foot off the brake and brake again and the brake engages. Right now the car is in the garage, and I am about to start some much needed engine work. I am thinking I need a complete brake system change. Does anyone recognize the issues I'm having?
i had similar issues with my 95.
I fixed it by replacing all soft lines with braided stainless, all new calipers, and doing a complete reverse flush, i had moisture and air in the lines and ABS system, along with the rubber lines expanding. having the brakes bled at a dealer was the important step for me.
Cobra's will actually be harder to lock up than the stockers due to the size of the MC.
-Alan
It sounds like you may have some air in the system. Bleeding brakes with ABS systems is typically a pain in the @$$, as they'll usually require you to run the ABS pump during bleeding.
