dnsherrill
(I tried to make this brief)
I have two Marks, white and brown- re-doing white car brakes currently
-I removed all 4 rotors from The Brown One (it's currently on stands in the garage)- rotors measured ok so I had em turned
- both rear calipers on The White One had torn dust boots so I took the calipers off the Brown One (they looked ok) and put them on the white car, with new Wagner pads and the turned rotors from the brown car
-on the White car, I used the turned front rotors and re-used the old pads
-to bleed, I used a vac pump/tester and cannister to bleed the brakes myself; RR, LR, LF,RF 2x around,I also slightly depressed the E brake a few times to try and engage the ABS pump; also started the engine and pumped the pedal to expedite filling the cannister a few times
- drove it, front drv side caliper inside pad was put in backwards, drove it to/fro work-90 miles; front rotor and pad destroyed and removed, replaced with the rotor that was on there, I put in a used pad with about 30% left
-now, when I drive it, the pedal has normal resistance (not soft at all) the front end shutters some when stopping, and at very low speeds, just before coming to a complete stop, the pedal sort of 'pulsates'- feels like it's pushing back
I've ordered new front Wagner pads and EBC front rotors to be installed next weekend
no ABS light on, no problem stopping or slamming on brakes, firm pedal except when almost stopped- then it pulsates
could I have lost my proportioning valve? just a crap rotor, pads= unbalanced front braking?
