Best way to black-out chrome?
Lincoln Mark VIII
  1. sprocket
    sprocket Well-Known LVC Member
    442
    13
    Jan 28, 2013
    Hastings
    This Diamond Anniversary I bought has a lot of the chrome blacked out, but the owner who did it used some kind of blackout tape and it doesn't look very good. Also, some of the chrome is not blacked out, including the grill.
    My first plan was to remove the tape and replace any bad chrome, but I talked to a guy who knew the owner who blacked it out and apparently there is quite a bit of defects in the chrome. Also, the blacked out look is starting to grow on me. Now I like it!
    I've already received the advice to paint all the chrome the color of the car, but I don't think I will go that route. I think matte black makes a good contrast to cordovan. Anyway, I'm getting long winded again so I'll get to the question:
    What's the best way to black-out the chrome and not spend a ton doing it?
  2. Epwillis
    Epwillis Dedicated LVC Member
    547
    35
    Jun 19, 2012
    Dearborn Heights, Michigan
  3. Miksweets
    Miksweets Active LVC Member
    176
    7
    Jan 9, 2013
    Atlanta, GA
    Agree plasti dip all parts in matte black. That's my plan in about another month is to plasti dip my whole car and do very little chrome on my mark.
  4. Miksweets
    176
    7
    Jan 9, 2013
    Atlanta, GA
    I'm going for roughly 6 to 8 coats. So no zebra stripes and better for when I'm on the road so much.
  5. stu
    stu Well-Known LVC Member
    353
    9
    Mar 12, 2010
    co
  6. kaha
    kaha Dedicated LVC Member
    726
    16
    Mar 15, 2011
    Butte Montana
    I've never heard of this. Is it cheaper than paint?
  7. Lownslowlsc
    Lownslowlsc Dedicated LVC Member
    6,621
    219
    Oct 4, 2007
    N il
    No, but it's durable and removable. Check out the links.
  8. kaha
    726
    16
    Mar 15, 2011
    Butte Montana
    oops, info was just a couple comments up. :slap:
  9. sprocket
    442
    13
    Jan 28, 2013
    Hastings
    Thanks for the advice. I've seen these videos before and they had a special paint gun.
    I have a couple of Wagner power painters and I have a fine spray nozzle. Would that work?
  10. UltimateSVT
    UltimateSVT Dedicated LVC Member
    4,612
    165
    Jun 21, 2009
    Miami, FL(Home of the rust free MARK VIII's
    Search my old threads. I do this to all of my Mark VIII's. You are bound to find stuff on here. I've explained it a few times on lvc. If painted correctly you will have a good painted surface for years.
  11. 95mark8newyork
    95mark8newyork Dedicated LVC Member
    1,318
    14
    Sep 4, 2011
    USA
    Just plasti dip it. It's not permanent, you don't gotta sand anything down. All you gotta do is tape off what you don't want sprayed and then spray what you do want sprayed. Make sure you do atleast 4 coats so you can peel it off easily if you ever want to.
Share This Page
