topher5150
got it home safe and sound now i just need to wait for the parts
if you remove the struts, take a flathead and pry all the flags off the heads of the bolts ( all 4 ) then slip an 18 mm wrench on the nut under the master cylinder and use a ratchet and 15 mm socket inside the wheel well, on the heads of the bolts and break it loose, i do this to everyone i work on it cuts an hour off the whole job , makes life alot easier and gives you more time to sip more beer after the job is done, you can sit back and admire what you did and get drunk too!!
i had my mechanic check it out they said it was the upper control arms
