joegr
I suspect that the police IR laser systems can very effectively filter out most other sources of IR.
I once designed an IR based proximity detector to detect the presence of notes at the exit of a dispenser. To prevent the IR from sunlight (DC source) and the IR from room lighting (120 Hz source) from causing false triggers, I modulated my IR source at about 2 KHz. I then used a band pass filter on the receiver amplifier centered at 2 KHz. This made the receive circuit very immune to influence from anything other than it's on source emitter. I suspect that the laser systems do something similar, and I would guess that the laser jammers modulate their IR outputs to the same frequency as the lasers are using.
