thaywood
Okay, my '97 LSC has been running fabulously...until yesterday
Out of the blue, it started missing. As soon as it started, the ABS light came on. Then the "Check Traction Control" warning came up on the display. Then the CEL started flashing and then stayed on. The whole time, the car felt like it was running on 3 cylinders. Unfortunately, I had to drive it 40 miles home from work like that. On the way home, I noticed that if I turned O/D off and kept the RPM's above 2500, it ran relatively smooth. Anything under 2500 and it spit and sputtered like it was going to knock off. There was also a definite "rotten eggs boiling in sulfur" smell similar to what it smelled like before I had the 3rd cat removed. I limped it home and parked it last night and started it back up this morning in the hopes that it may have "fixed" itself
No dice. Still missing like crazy. I need to pull the codes, but I'm afraid to drive it 20 miles to Auto Zone to check it. And I don't have a code reader, nor can I afford one. I'm going to go out and pull a couple of the coils out and see if they're cracked or deteriorated later if it stops raining. Anyone else had this particular set of problems before? I find it odd that the ABS, T/C, and CEL all came on at the same time. Makes me think they all may be relating to the cause of the problem. I did turn the T/C off just to see if it made a difference. It didn't. Anyone got any suggestions? Thanks.
