05 LS8
Nice work there man. What did you use to hold the plastic (that goes over the side marker) in place? Do they just snap into place?
Alax is the man.
Bad ass job dude! looks so damn nice...done like a pro!
How are you controlling the angel eyes? Do you run them off of a switch, or tie them into some existing circuit?
I have mine wired to the parking lights. White wire on the rings with black/WHITE wire on the parking light harness, brown wire on the rings to the black/BLUE wire on the parking light harness.
They turn on if you turn on the parking lights. If the parking lights are off and you use the turn signal, that side ring will flash with the turn signal. If you have the parking lights on and use the turn signal, the rings wont flash. If you have you headlights on, your parking lights are on so the rings are also on. They will also flash when you lock or unlock your car which is real cool at night.
The people that I have done the install for said that they wanted it the same way, maybe they didn't want to worry about wiring it themselves, but thats how i've wired the ones I've done.
You can do a switch to them. You can also use a relay, but I haven't used one and they work great. I also tried wiring them to turn on with the puddle lights, that was cool but I didn't take my time so ran into problems.
