BigPip
Talk about buyers remorse - I can't seem to get ahead with this car.
The other day the battery light came on and I decided I was going to do the 'Big 3' and while I had it a part I had the alt tested and the results came back good, then I had the battery tested and it came back good. I continued the 'Big 3' and after I finished wiring everything up I hooked the battery up and instantly the alarm ( horn & lights) started going off and nothing would turn it off. I tried both door locks with the key, full turns both directions, keypad lock, unlock, panic and using the key pad to lock and unlock the car but it keeps going on and on and on... The only thing I can do is pull fuse #6. interesting enough if I insert the fuse, the alarm goes crazy but I can pull it right back out and it stops, It doesn't keep going.
The battery has been unhooked for about 5 days but I can't see where that causing an issue.
For those who have done the Big 3, mad props- the bolt for the engine cable is a P.I.T.A.!!!
Any ways, if anyone has any suggestions I sure would appreciate it!
