98 lsc black on black progress and question thread
There coming the car is so dirty that I don't wanna post pics till I gets decent day to clean it. Mechanical always comes first on my rides but I'll post some dirty pictures today and then post pics once it's cleaned
Also the chrome 10 spokes are totally destroyed I will have to find some wheels for it maybe some octo's or even settle for painted 10 spokes
The ABS sensors would explain a no speedo condition as they read speed off the abs sensors... they are 98 only... I have a set of rears and one side of the front if you are interested.
I inspected and checked the sensors out everything looks good I cannot see all 4 sensors at the same time being out and i also noticed the odometer will work when you start it then after it starts goes blank and says "-------" I also have other abs codes not just wheel sensors
Always stick to OEM's when it comes to coils. Ran fine for 13 years with OEM's, that's a good track record. ;)
Thats partially true. The Accell suck, do not get. The MSDs I hear mixed reviews. Seems they have a strong spark and charge fast but some say they only last a couple years before failing.
I dont know what I have as they are labeless but the were only $17 each new, shipped. I have had them 6 months and about 10k and they still spark strong. When I data log them they are all exactly the same with a strong output. They were from ebay and the ad just said OEM replacements so I thought they were OEM. Meh, they work.
Looking for 97 98 abs pump and unit with connector
I may have one. Ill go check.
Please let me know I'm prepared to paypal the money asap
Hurray for photobucket app couple crappy pics one on the highway yesterday afternoon sitting my other car on break and a couple last night I texted my buddy to show the lighting
Yeah I searched earlier and found the thread earlier today im checking for that tommorow and I'm also gonna bring my spare relay as well my car is doing exactly what you described and I have alot of U0000 codes amongst the 4 wheel speed sensor codes I hope my connector is not cooked but I def know my problem is likely in abs cause I have vss working on scanner and showing me data
I found out later (in that thread) that the Gen 2 doesn't use an ABS relay.:)
That relay is for the emissions air pump in the Gen 2.
Remember if you have to shange the ABS pump it is year specific 97 to 97 and 98 to 98, no mixy matchie on this baby!!
I ended up just picking up one oem for now car is running great now but plan to get a complete set for spares
Also replaced front sway bar end links now all the clunks are gone and somebody already did lowers uppers and srb's
All that's left is abs unit and oil filter adapter housing gasket and a couple other small things
Got it installed odometer works speedo works All lights are out drove about 10 miles and abs light came on I'm assuming a wheel speed sensor I'll scan it tommorow and see think I need to run the abs bleed with scanner again and probably bleed system some more peddle is slightly spongy But atleast I got my trip data Milage and everything back
