NoLimit95
In jerry's trans article, it specifically states not to use the longer ouput shaft of the towncar/police crown vic in high hp applications.
Actually it was torque that he mentioned, not HP. The information about this being behind a blown 450 HP was left out to begin with and still hasn't been verified by the OP but anyway, if it is going to be behind 450 HP, I'm sure the long shaft can withstand the torque coming from this. 480 ft. lb. or above, then no, I wouldn't use the long shaft. The worst that could happen, according to Jerry is that the shaft could either break or twist. My guess is that the torque from the 450 HP blown engine will be below 450 ft. lb., just guessing.
What's Roadboss at? 535 RWHP and 486 RWTQ
SVO, by no means do I think you don't know what you're talking about. I know you know your :q:q:q:q. My point was that for under $500, he could have a good transmission but if it's going to be dogged out at the track and making passes, then he should find him a 98 or 99 short shaft and do the electrical internal swap and j-mod, drilled out to spec for his HP rating. There is no way I would ever consider rebuilding a 93-97 trans. If a low mile 98 or 99 can be found and it's known to be good and can be bought for $350 or less, that's how I would go.
