a messy engine bay lol.
I'm spraying 100. Thats the most I have sprayed. They say the difference from 100 - 150 is incredible.
Once you drive a car with Nitrous, you REALLY understand why the call it "laughing gas". It will put a smile on your face.
its like v8 vtec the way it just instantly changes everything about the motor and power. yea its awesome but 150 doesnt last long in a 10 lb bottle.
Are you running dry or wet?
im going 150 even with the lms chip on there... no problems - plugs look great. He says its cool to run with a 100 shot, ive ran it many times with the 150 no issue. Very happy with the tune. I'm no expert but i'de be willing to say its mild yet very safe tune. 50 lbs of nitrous later im still good!
what does it cost for a bottle refill...................
I have a similar setup. The throttle switch is under the pedal for me and I use the arm switch at wot after 3-3500 k. What do you gap your plugs at? Do you spray through shifts? The lms maf is just the maf right or does it include a cone filter? What shift kit did you go with?
The only problem With Nitrous is that the Bottle runs out. Twin screws though.........
