1995 Mark VIII Rear Diff fit into my 1998
What drive shaft you guys recommend?
93 shaft will work, some have vibration problems I have a 93 shaft with 4.10s and am good up to 100 mph.
I would do both at the same time and install a new fuel pump while the tank is out.
One wheel method FTW.
Makes install a snap.
Use Carpart.com to find a cheap shaft in your area.
** Didn't realize the tank needed to be removed in this process? Or are you saying drop the tank while it's there and replace the pump?**
Since you are swapping the pumpkin you can pull the drive shaft without dropping the gas tank. Be sure to get a new output shaft seal. I didnt and guess where my car is leaking from? :lol:
Really though since you are doing performance upgrades its a good idea to swap the fuel pump anyway. The stocker is barley adequate as is. Get a Focus pump.
^ What he said!
Will do, looking into a centrifugal S/C as well so the fuel pump will definitely be a must. Thanks for the assistance dudes!!
