LongIslandLSE
what filters do you use. I do my oil myself because I dont trust the 18 year old at the local lube shop.
why, what us the advantage of dealer oil changes.
I recommend wix filters to everyone, they have the lowest pressure drop across them of any on the market and a very good particulate pass efficiency, keep in mind most junk under 25 microns is too small to hurt most engines, so those filters that say 3 micron first pass filtration are doing so at the sacrifice of oil pressure, some weve seen in testing drop almost 20psi the wix filter for our cars only drops 4 and my oil was always clean
my engine failed due to particulate contamination from failed lower intake gaskets, sucked sand into a #2 & #7, had nothing to do with the oil, although im not sure if i'll be using 0 weight anymore
i use mobile 1 clean 5000 and fram filter.
Since i started racing i change it out literally every 1500 miles lol..i just get bored some days and im like WELL! guess ill change the oil! and its only been like a month and a half since the last one.
X2 Fram sucks.You might want to re-think you choice of oil filters, do a web search on Fram, for about the same $$ you can get a better filter.
I just change my oil when it starts to look bad. I check it every week or so, and when it starts to turn really dark it gets changed shortly after. Ive had my LS for right about 15k miles now. Have changed the oil twice. First time was when I got it I used Motorcraft 5-20 and motorcraft filter. Ran that for 5k miles and it still looked decent, but I went ahead and changed it anyway with Amsoil 0-20 full synthetic, and a Wix filter. Been running Amsoil for right about 9.5k miles now and it still looks petty much fine. Changed the filter at 5k, and am getting ready to order an oil analysis kit to see what kind of life this oil has left.
X2 Fram sucks.
