High beam angel eye not fitting
Cronos
Georgia
So I cut my headlights open. It was a pain in the ass, but I did it. I get how to mount the low beam angel eye on the benzel. But how do I mount the high beam angel eye? It doesn't fit on my benzel, do I cut the clips petrifying out from it off? How did you guys mount it
I also realized my low beam angel eye isn't completely round like you guys have it. I ordered the predator Orion v2
I know you seperate the big rings to fit the bowl, but I'm talking about my small ring
They all should have the bar on them. There is no differentiating the low beam ring from the high beam when you get them. These are not direct fit items. You need to cut the high beam rings and remove the bar and seal the ends together so they fit in the bezel.
What year are your headlights?
If you have a gen1, your rings will not be round, they will be half circles with a plastic bar going across them.
if you have a gen2, your low beam rings will be har circles with a bar going across and your high beam rings will be small, full cicles. IF your high beam rings have a bar across them, you might have bought gen1 rings.
they all should have the bar on them. There is no differentiating the low beam ring from the high beam when you get them. These are not direct fit items. you need to cut the high beam rings and remove the bar and seal the ends together so they fit in the bezel.
huh?
It's been so long since I saw the rings when I got them. They weren't all the same? My bad, now I feel like a moron. I will go and hide now
Oh :q:q:q:q, dam on the umnitza website it shows 2000-2006. I'm just gonna have to customize the small ones :/
Even my order detail says "1x Preadator Orion V2 for Lincoln LS (2001-present) :q= $199.99
:q :qCar Model LS 2003-2006"
haha nice one.For gen1 they are, for gen2, you get a small ring that fits the hi-beam bezel
Take a picture of it, DO NOT CUT IT WITHOUT SHOWING US!
You can just return it and have them send you another one. I really doubt you can make a gen1 ring fit in the gen2 hi-beam bezel, well it wont look right if you do.
Looks like the gen 1 ring. If you have a gen 2 send them back and get the correct ones.
I emailed them and they said for my year Lincoln 2005, that's the kind I need. So I asked them how I'm supposed to mount it and they said send pics. This really pisses me off cause I already mounted my big one on one headlight, and now I have to find a way to temp reseal . Sigh
Tell them you need the rings from the x5, the small ring has to be a full circle. Or just tell them to ask lightwurkz the correct rings cause they're fuuuking up.
I emailed them. I already mounted one ring with the center cut. Do you think the quality of the ring and look when it lights up will be different from the 2nd gen? Or can I just leave that one mounted?
Where is the 2005 Lincoln ls accessory wire? I'm just going to tap my trigger wire into the accessory wire and then put my headlight back in and wait for umnitza to act
Yea that ring should still work, looks like the same anyways.
Just need to get the hi-beam full circle rings. I bet you can shipem just the smaller ones and they'll send you the circles.
