SC93
My LS won’t start, when I try and crank it makes a weird sound… almost like it’s not getting enough juice to spin the starter at all or maybe mechanical (I’ve only tried a few times…). Headlights have full power everything in the car powers up. 12V at the battery.
I tried boosting the battery with my charger (50 amps). I crawled under to get a quick look at the starter everything looks connected correctly.
My battery is just under 1 year old. I had a quick look at the fuses under the hood and they look ok. My car has just over 130,000km so I’m hoping the starter hasn’t just up and die on me without any symptoms.
Background (long):
I washed the car (a few weeks ago), parked inside my garage, wiped around the door seals and put a little car heater inside for a few hours. Took the heater out and a couple day later I went to drive to work in the morning and the alarm was going crazy… it must have going off for a long time because all the lights were dim and the horn was blowing very silently. I open and closed every door and got it to stop (punched in my code), I think maybe one of the doors got frozen open a little or something, I also had a flat tire too (I must have run over a nail on the way home). When I got home (took my other car) I put the battery on my charger for the night and pulled off the flat tire. The next day after work I checked the battery it was at 12V so I started the car up and let it idle for a while and shut her down.
Last Saturday my wife went to use the car and she came back in saying it won’t start. Sure enough it just makes a weird sound when trying to crank. The car hadn’t been driven for a few weeks and just doesn’t want to start now??
I searched and haven’t seen any threads on strange noises from a starter. I did try a few things that were suggested for no starts (fuses, proper connections, battery, PATS…).
Any help appreciated before I have it towed in to have it looked at!
Background (long):
