Jamie? cut out a blend door
Right on the Mark
here
I'm parting out the 97 that Ford just put a blend door in. Is it worth it to cut that sucker out. I was wondering if you had a 1-2-3 on how to remove it by cutting what ever is needed to remove fast. I know you did this a million times. Thanks
Cut it out? Just unbolt the dash it's only a dozen bolts! It would take longer to cut
I just wanted to know the fastest way to get it out. If I can sawzall for couple mins and get out that would be cool. Thats all I wanted to know.
Yes its all labor.
remove the dash so you can learn how to do it yourself. If you break something it won't be so bad.
Yes its all labor.
I have a Gen1 these don't seem to break as much on Gen1"s?? Plus I don't think I will ever own a Gen2.
