22"s on Ls (offset, width and tire size)
These should work. Gotta have a shop drill the bolt pattern for you:
Any of those come in chrome?
If he's going to put 22's on his LS, then I strongly believe the F5 should have just picked his car up and uhhhh... I guess tossed it into Springfield or something equally destructive. You know, just to put the LS out of it's own misery.
Ohhh and to the OP: if you start getting a slight misfire and someone tries to tell you it is the coils, don't listen to them. You'll never fix it. Just sell it.
F5... i wasn't going to go there LOL......and thats assuming its not misfiring already
I have a 2002 Lincoln Ls on 22's ' its rides waaay better then stock wheels, only problem I gotta raise it up an inch ' either get new/stiffer springs ' or coil spring spacers... My rims are 22x8 245/30/22 falken tires 35 offset, ' I think my ride looks siccc with the 22's ' jus need to raise it up and il be cruzin! ' not 1 person has told me my car looks bad with the 22's you be the judge :P http://www.cardomain.com/ride/3912257/2002-lincoln-ls-v6-sedan-4d
Best part of that page is the blonde with her t!ts hanging out.
There is absolutely no way that less rubber would equal a better ride. Unless you reworked your suspension or your stock rims or tires were completley shot, and I mean shot to hell.
Rubber = soft
Metal = hard
Its within their molecular make up, which we cannot change.
As long as you like it. If you raise it, we will laugh. I think you missed the reason for this thread.
