New use for two piece driveshaft...
SATURN5
Dr. Frankenstang
in the shop
I replaced my original 96 shaft with a 93 a couple months ago. Over the weekend, I pulled the stick axle out of my SVO and put in a 03/99 Cobra IRS.
But I still had the Mark driveshaft sitting in the corner, I set it next to the steel shaft out of my SVO. And the wheels begin to turn...
So last night, I decided to cut up the old two piece driveshaft from the Mark VIII. Little tube is bonded to outer with rubber. Once cut to the correct length a little drill and sawzall action freed it from the main shaft...
I took the cut end/yoke over to the lathe and cut the original weld and freed the yoke from the old shaft. Lined up my marks I made prior to cutting, keeping the yokes lined up.
Steel shaft next to my new aluminum shaft.
Today I took it to work and had our fab guy Tig it for me....
So I need to cut off the original balance weights and have it balanced... New u-joints, and she's ready to go..
I tried to give mine away for free with no takers. Nice SVO.
I would recycle. Probably get a few bucks for it in todays metal market!
I cut the ends of and leave that part stuck in the end of the transmissions I pull. Keeps the seals in good shape and doesn't let the fluid leak out.
Anyone else see that carbon fiber D.S. On one of the other mark viii site for sale $800. Sowwie thread jack
It's true! Seen it with my own eyes, even though you could do some rounding on the edges, since they're so sharp. :p
IRS on an SVO! Me likey! I'd like to find a good 99/03 Cobra IRS setup to put in our '96 Cobra. How did it change the ride/handling characteristics of the SVO as compared to the log axle?
Haven't driven it yet. I need to finish the wiring for the Megasquirt and build a diff for the IRS.
Cylinder head $250
New stainless exhaust valves $80
Decking $45
Diamond pistons $250
Crower rods $200
Fresh machined block and crank $150
ARP head studs $75
Holset HE351 $200
75lb injectors $225
Cam pulleys $150
Toyota coils $50
generic 44mm wastegate $100
Materials to build intake, fuel rail and header $200
4 puck clutch $150
Intercooler cores and sheet stock for tanks, $200
Materials for BOV $25
Intercooler ducting/hoses/fittings $200
Just over $2700...
Geez.... Really the first time adding it up... :rofl:
Spent over ~8 years
SVO $1900
Tires/wheels $400
Cobra brakes $250
late model hubs $75
MM control arms $350
Cobra rack, hydro boost $300
Bilsteins front and rear $250
T-top frame and seal kit $750
Megasquirt $250
Aeromotive fuel pump, filters and regulator $200
-8AN line and fittings $250
Paint $600 (traded work for actual color and clear materials) ~+$1000
Almost $9500 to this point, and I've yet to start the interior.
holy :q:q:q:q.... is that a 4 cylinder???? i haven't really got too much knowledge when it comes to stangs especially fox body
Ooooooh! Me likey! Seriously, that is one seriously nice SVO. What year is it? I've seen a couple of SVO's running the "Folvo" head. That DOHC cam cover just looks perfectly at home under the SVO's hood. That's what Ford should have done in the first place. When the SVO came out, Ford had a 250hp turbo DOHC 2.0L 4-banger in the Sierra Cosworth in Europe. Why they didn't just put that engine in the 'Stang is beyond me.
