the1andonlyGR81
http://www.ebay.com/itm/8-8-tractio...ies&vxp=mtr&hash=item415e7d528f#ht_586wt_1139
anyone want to tell me if this will work?
Some say you can just run axles without the "c" clips??
yes.
i am running axles with no c clips. nothing moves. i was under it the other day and tugged on the axles, no movement.
the trac lock? if its in the car, punch it. 2 lines = good. 1 line = bad.
out of the car, pull the s spring, disassemble the diff, and inspect the clutches. if they look bad, replace them. if they look good, replace them anyway cuz its already apart the rebuild kit is only like 70 bucks. or 110 for the cobra carbon clutches.
http://http://www.americanmuscle.com/ford-racing-88-lsd-28spline.html
Check that out. I just bought one a couple months ago. They used to be $179, but still not a bad price. I had a coupon code at the time also, for like 10% off. This way you don't have to worry about rebuilding....and about the same price when you figure in the cost of rebuild kit/labor...
excellent help, thanks guys. i believe im going 4.10
Don't fear the gear 4.10's are a nice pick.
yes,master
