How hard to replace Rear hubs?
turn_on68
New Braunfels, Texas
How hard is it to replace rear hubs. Seller on eBay has a foot note that it can be difficult to get old hubs off. These are OEMs for $25 each with bearing.
It takes a press.
I used a set of bearing/gear pullers to pull the hub....
bearing pullers with a socket to remove and install bearings...
its really pretty easy if you know what to do. i did both my rears in about 50 minutes as in drive in and drive out.
I'll write him and see what he says?
Thanks for bringing that to my attention.l
i bought a set from him.
no bearing. they were in excellent condition though.
what you see is what you get. except mine have been drilled for mustang wheels.
Here is what he said.
"THIS IS THE HUB ONLY - THE REAR SPINDLE OR "KNUCKLE" HAS THE BARING PRESSED IN IT - IT IS NOT PART OF THIS HUB. THANKS!!"
Thanks again for catching that.
the fronts are super easy.
remove the front wheel and brake hardware. unbolt hub. remove hub. preferably a new nut. put new hub on. tighten. brakes and wheel back on.
Front are simple. Remove the caliper and rotor, bearing cap and remove the nut. Reverse using a new nut, torque to 250lbft.
