warrioralumni08
Well, I bolted the trans back up, and made sure everything was correct. I took the torque converter off and just put it on the flywheel and bolted it up from there. Then I put the trans on and it felt like it went in right, after a couple of tries. I can turn the crank pulley and it spins, but the tail shaft isn't spinning. Should that be a concern? I am thinking it won't engage until I hook everything back up , and it sends a message to the computer that it's shifting. Just a bit concerned.
