jolinc01
You can always trace the wires in the gen 2 light then match up the harness wires. Took me 20 minutes to do it that way.
The ones in the amber lenz in the turn signals? I wired those to blink with the turnsThe only thing is the small LED running lights do not illuminate.
I know that when everyone swapped head lights you mostly all swapped the facsia to avoid the dreaded gap, are the hls themselves (specifically the lens) a different size or shape? Could a gen 1 lens be sealed onto a gen 2 hl if they were both dremeled apart in the same way? I ask because you can buy a set of brand new gen 1's cheaper than a single used gen 2 and my lenses are scratched so bad they'll never be perfect even with refinishing.
clean!! so i can get gen 2 headlights on my 01 ls?
