BAD97LSC
lmao
no, you dont know the story, originally the car was supposed to be stored at my shop until brandon came down, rich was gonna drive it up and leave it at my shop, brandon could have wiped off 4+ hours just coming to me instead of all the way down to ft lauderdale, its was all planned then before i knew it, brandon was here in florida and no one said anything to me until i get a text from rich saying brandon was on his way to my shop, 2 days went by and brandon was back up north! so oh well i didnt lose sleep.
now, onto the problem here, why dont you stop guessing or letting others guess and start with the obvious here, get under the car and unplug the compressor, the harness has 4 wires in it, a white, blue, black and red. the red is pos and black is neg for the compressor power, get 2 wires and a battery and put power dirrectly to the compressor to see if the terd even comes on, if it does, take the same two wires and touch a pos wire to the white wire, and a neg wire to the blue wire and see if the solenoid clicks, if it doesnt click, change the compressor, if the compressor doesnt run smooth and fast, change the compressor, i put my money on the compressor, specially if its an arnott.
Yeah but at the same time you cant ask a friend for a favor and then get mad when he doesnt do an extra favor and eat into what little time he has. Good way to no longer get favors.
Yeah it would have saved a lot of time effort and money but on the other hand Brandon didnt have time to work at Jamies shop for 8 hours fixing and replacing stuff.
yeah but hanging out with a cute girl and having to go back to the hotel to beat your dick like it owes you money isnt really all that fun, now had you got laid, you could tell all of us to stfu, but you didnt, so you cant, the only ass you get is when your finger tears through the toilet paper, now go fix the car mr confident big head.
So... thoughts?
So that's where I stand... If I apply voltage where the relay is supposed to, the compressor turns on. If I ground the wire that's supposed to engage the relay, nothing happens. But it somehow isn't the relay. So... thoughts?
I had a hard to diagnose problem with my red Mark a few years ago.
I measured 12 volts at the power wire to the relay, but the compressor still wouldn't come on.
Then I ran a separate fused 12 volt (big gage) wire directly to the relay plug and it worked.
I think somewhere in the wire between the power distribution box and the relay, the wire was bad, it would still show 12 volts, but couldn't handle the current required by the compressor.
I needed to drive the car then, so I put a proper terminal on the jumper wire on the battery side, I'd already soldered the proper fuse in line, then I soldered the other end on to the pig tail of the relay plug (I just cut off the original 12 V supply wire).
I always meant to go through the harness and replace the wire properly, eventually, but it worked fine like that for years, and I never got around to it.
I'm not saying that this is your problem but it's an easy thing to try, run a good power jumper wire (with fuse) to the relay connector and see if it works, either by grounding the trigger wire or just keying the car on.
Buy a used coil conversion set so you can drive your car while you are figuring out this electrical issue.
Darren Bill is saying exactly what I said yesterday... just because there are volts doesn't really mean much.
