ramairmustang
Okay I just had my fuel pump replaced with a 255lb on from scp.com because my car would seem to stop getting fuel under moderate to hard acceleration. It would just stop accelerating for a few seconds then kick back in. I had it checked by Jake Sweeney Chevrolet/Mazda and they said it's the fuel pump. So they replaced it with the one listed above. Got the car back and it's much much better but it will still jerk and lurch a bit under moderate ro hard acceleration but not as bad as it was doing. It does it more in this situation. Say you are going 55mph in 4th gear and you start climbing a hill, you feed into the gas pedal just a bit more to pull the hill but not enough to comand a downshift into 3rd. It will start to jerk untill i either back off the gas or push the button to downshift into 3rd. After performing it downshifts into 3rd everything is fine. But now if im going say 30mph and kick down to 2nd to accelerate it does that same jerky :q:q:q:q. I've replaced the plugs, wire, coil packs, injectors, fuel filter and now the fuel pump. Could this be my Idle Air Control Valve going bad or the Fuel Pressure Regulator? I dont know. I am about to get my body work fixed a very very nice Black Cherry paint job done this summer and would like my car to run good as well. Oh also I was getting about 16.6mpg before the fuel pump was replaced now im getting 20.2mpg.
