Ok SO first I have used search on most of this but not allot of concrete answers to be found. I have a few thing I plan to do in the month I have before I drive from Columbus Ohio to Coco beach Fla to Detroit mi and back to Columbus SO I need to be 100% about all my moves to prevent delays.
So I am thinking of saying screw it and buying new wheel that I like and not that I can find used. after a hub swap any reason these will not work?
Offset: 35mm
Backspacing: 5.90"
Bolt Pattern: 5-114
Rec. Tire Size: 255/45-18
Weight: 23.5lbs.
Finish: Bright Silver Paint
Construction: 1 Pc.
I know 8in wide wheels will limit a tad but it is my driver I have a "fast" car so 275's will be enough
2. I have a 04 cobra irs to use for parts I plan to use the center and both axles (31 spline) and the hubs with new bearings. Questions from this are
: any issue using the cobra axles?
: Do I use the mark bearings or cobra (assuming they are not listed as the same part number)
: Other than the adapter bracket for the caliper and new rotors will I need any other parts for the rear?
3.Exhaust.. Anyone make a catback?
:anyone used these guys? http://www.mandrelexhaustsystems.com/servlet/the-117/93-dsh-98-MARK-VIII-EXHAUST/Detail
4.Sensor drop, I like the control box but I dont have time or cash for that atm so anything I need to know about this does 1in at the sensor = 1in drop?
5.Cobra intake (mine is a 98 lsc) I have a 98 cobra intake , What are real world returns for this swap power wise? What is all needed to complete the swap? is there a write up I missed?
6. Drive shaft anyone have one for sale close to me? What year t-birds work? 93 mark as well too correct?
Oh and I will do a build thread with pics once I start in on her
Offset: 35mm
Backspacing: 5.90"
Bolt Pattern: 5-114
Weight: 23.5lbs.
Construction: 1 Pc.
