Ohh blah.. Posted at the same time..![]()
It took me 5 minutes to post that with my typing "skills"!
2nd gen you DO NOT need two remotes to program others.
I do believe that he was talking about keys, and not remotes. The statement is true for keys for gen I or II.
Okay so i found this thread today after i received my keyless remote in the mail today. I did exactly as posted and i got nothing. i did a couple of times and still nothing, any suggestions? i have a 2002 LS8. I looked in the owners manual and it said to take it to the dealer, don't want to pay them if i can some how do it myself.2nd gen you DO NOT need two remotes to program others.
From the 2004 OWNERS MANUAL:
Replacing lost remote entry transmitters
If you would like to have your remote entry transmitter reprogrammed
because you lost one, or would like to buy additional remote entry
transmitters, you can either reprogram them yourself, or take all
remote entry transmitters to your authorized dealer for
reprogramming.
How to reprogram your remote entry transmitters
You must have all remote entry transmitters (maximum of four)
available before beginning this procedure.
To reprogram the remote entry
transmitters:
1. Ensure the vehicle is electronically unlocked.
2. Put the key in the ignition.
3. Turn the key from the 1 (LOCK) position to 4 (RUN).
4. Cycle eight times rapidly (within 10 seconds) between the 1 (LOCK)
position and 4 (RUN). Note: The eighth turn must end in the 4 (RUN)
position.
5. The doors will lock, then unlock, to confirm that the programming
mode has been activated.
6. Within 20 seconds press any button on the remote entry transmitter.
Note: If more than 20 seconds have passed you will need to start the
procedure over again.
7. The doors will lock, then unlock, to confirm that this remote entry
transmitter has been programmed.
8. Repeat Step 6 to program each additional remote entry transmitter.
9. Turn the ignition to the 1(LOCK) position after you have finished
programming all of the remote entry transmitters.
10. The doors will lock, then unlock, to confirm that the programming
mode has been exited.
Well, those instructions were for a gen 2. You have a gen 1.
Still can't get over the fact that the code is nowhere to be found inside the car somewhere... What was Lincoln thinking?
