Raped Ape
Well I have surgery that was laid on my plate last week as a must have or could have a more difficult road for me if I do not have it now. My injury is called Cervical Spondycolisthesis, which means I have multiple cervical vertabrae that has basically torn away from the spinal alignment. My surgeon says that I having it in my cervical is rare due to it happens mostly in the lumbar and thoracic part of the spine. If it tears completely then I am screwed. It is considered on the scale of 0 to 4, mine is a grade 3. I furthermore suffer from nerve damage to my right and left arm from the inpingement of the nerves from the tear away.
My C-3, and C-5 have both seperated from my spinal alignment and requires disk removal on 3 vertabraes and fusion on 5 out of the seven vertabraes with metal plates and 12 screws. This is my issue at had that I suffered from an injury in the war when a 5ton cargo truck fell on my head while taking a oil sample and now has gotten to the point of having this procedure done, this is a little picture of a grade 3 tear away.......
And this is the procedure that I will have in animation, but instead of herniation of the disc, mine is due to the tear away, but same procedure.
http://www.esurgeon.com/scripts/con...caldiscectomywithfusion.html&doctorname=Jaime Alvarez, MD&doctor=alvarez
I have been told I will have lose of movement to a percentage of 25% in the up and down motion and about 10-15% side to side. Once they fuse together in about 6 months, then instead of having 7 cervical vertibraes, I will have 3 moving vertibrae in the cervical spine.
