driveshaft
how would i go about testing the coils on my 1995 mark viii? it's running rough, seems to be worse when it's cold and wet out. already changed the wires, it seems a little better.
Have the car scanned. It will tell the truth if any coils are bad.
No, you need data stream, obd1 can't data stream... You've got 2 coils.. If 1 is bad, car won't start.
Remove wires from the coil 1 at a time with car running... When a wire is removed it will misfire instantly if working properly. Repeat until you pull a wire that has no effect. Then swap that wire with another. Repeat process on those wires...check spark plugs for proper gap ( .054)
