anybody know the lincoln ls bolt pattern??????help quick
Yep they will fit.
That should teach you to search next time :shifty:
Yep they will fit.
They will NOT fit. The LS has a 5X108 bolt pattern.
A simple search through the hundreds of wheel threads will have yielded this information.
the bolt pattern on the craigslist site that i put above is differnt from what "right on the mark said"
i just wana make sure these fit for sure before i sell the 20s i have...and i have no stock wheels so i dont wana b :q:q:q:q out of luck..
The LS bolt pattern is 5 X 4.25 which is the same as 5 X 108.
Just so you are clear, it is NOT 5 X 4.5 or 5 X 114.3.
And like many have said using the search function would have given you the answer.
The ad doesnt give you enough info for you to know for sure anyways
offset is also pretty important!
For that matter so is wheel width. There are many online calculators that will help find the best compromise between wheel width and offset.
FWIW, the stock wheel is 7 1/2" wide with a 60mm offset.
or google. can the mods put a limit on how many threads this person can make? needs a limit around 0.5 a year
