anybody know the lincoln ls bolt pattern??????help quick
Lincoln LS
  1. linc2linc
    linc2linc Active LVC Member
    73
    Feb 21, 2011
    oswego
  2. Right on the Mark
    Right on the Mark Dedicated LVC Member
    4,467
    384
    Nov 1, 2006
    here
    5x 4.250
  3. M4rk
    M4rk Dedicated LVC Member
    2,553
    122
    Feb 13, 2010
    Ontario
    Yep they will fit.
    That should teach you to search next time :shifty:
  4. LS4me
    LS4me Dedicated LVC Member
    9,952
    787
    Apr 23, 2004
    San Diego
    They will NOT fit. The LS has a 5X108 bolt pattern.
    A simple search through the hundreds of wheel threads will have yielded this information.
  5. linc2linc
    73
    Feb 21, 2011
    oswego
    the bolt pattern on the craigslist site that i put above is differnt from what "right on the mark said"
    i just wana make sure these fit for sure before i sell the 20s i have...and i have no stock wheels so i dont wana b :q:q:q:q out of luck..
  6. mlara1129
    mlara1129 Dedicated LVC Member
    4,100
    109
    Jun 29, 2010
    Tri-State Area
    do you do it on purpose?
  7. Lincoln Luebbe
    Lincoln Luebbe Dedicated LVC Member
    1,881
    Jun 20, 2005
    Lincoln Lane
    The LS bolt pattern is 5 X 4.25 which is the same as 5 X 108.
    Just so you are clear, it is NOT 5 X 4.5 or 5 X 114.3.
    And like many have said using the search function would have given you the answer.
  8. Villalta
    Villalta Dedicated LVC Member
    957
    4
    Jul 7, 2010
    ON
    The ad doesnt give you enough info for you to know for sure anyways
  9. linc2linc
    73
    Feb 21, 2011
    oswego
    what other info would i need..?
  10. LS4me
    9,952
    787
    Apr 23, 2004
    San Diego
    All you really need is the bolt pattern; which is plainly listed in the ad.
  11. linc2linc
    73
    Feb 21, 2011
    oswego
    so im guessin i shouldnt bother getting these rims...
  12. LS4me
    9,952
    787
    Apr 23, 2004
    San Diego
    Not if you want them for the LS. They WILL NOT FIT!!!!
  13. 1LoudLS
    1LoudLS Dedicated LVC Member
    9,870
    936
    Mar 31, 2008
    Ann Arbor
    offset is also pretty important!
  14. LS4me
    9,952
    787
    Apr 23, 2004
    San Diego
    For that matter so is wheel width. There are many online calculators that will help find the best compromise between wheel width and offset.
    FWIW, the stock wheel is 7 1/2" wide with a 60mm offset.
  15. dNyce LS
    dNyce LS Dedicated LVC Member
    2,127
    33
    Dec 6, 2009
    San Diego
    or google. can the mods put a limit on how many threads this person can make? needs a limit around 0.5 a year
  16. Villalta
    957
    4
    Jul 7, 2010
    ON
    Thats what i meant. But your right The bolt pattern isnt the correct bolt pattern so the other info doesnt mean sh!t.
  17. jolinc01
    jolinc01 Dedicated LVC Member
    2,787
    60
    May 11, 2006
    The Sticks
    He could always have them redrilled as long as the offset and width work. I might be playing devils advocate today...:gr_devil:
Share This Page
