DieselDan
Hey everyone,
I know a lot of people want to do this and since all the Ray Switch info is gone and locked away somewhere, I figured we might all be able to brainstorm here.
I had a few ideas and I know the principals that make the air suspension tick. I need to look at some wiring diagrams and try to come up with something.
First thought I had was cutting the harness at the air suspension module and installing a male/female aftermarket connector in series to the air suspension module so that the "lowering device" could be removed/installed, and not affect the stock operation of the air suspension, and there would be no ugly spliced and cut wires rattling around under the dash.
Anyway, I know that the height sensors work on resistance values and I know that you need to just trick the module into thinking the car is sitting higher/lower than it actually is. I suppose this could be done with 2 potentiometers, 1 for the front and 1 for the rear. I know that the Ray switch was a little fancier because if I recall correctly it used push buttons and a LED display. I would probably guess 2 numbered rheostat assemblies wired in series with the height sensor circuits could do the trick. I need to look at a wiring diagram, or just ohm a height sensor through its entire range of motion to get my resistance range, something like the below picture...
Anyway, I am brainstorming this idea. I think all the M8 owners with air suspension are missing out on being able to have control over ride height. I think this should be a easy (don't quote me), however the principal sounds simple enough. Please keep input positive, and knowledgable. Don't trash the thread up basically, please!
Thank You
Thank You
