Couldn't quiet find the answer
sweet~pearl
el paso
I read through a few of the threads, but I couldn't find exactly what I was looking for. My car sits level when parked and runing parked, but the DS is sitting about three-quarters of and inch lower then the PS. Both sides are even DS just sits lower. What would cause this? The bags aren't bad so I'm thinking its a valve in the air line, a sensor, maybe the control unit?
i guess height sensor.
My guess also. Use an 11mm wrench and lower the drivers side sensor a 1/4" or raise the passenger side a 1/4", which ever one you're able to do until you get leveled out and have the same measurement on both sides. Measure from the ground to the top of the fender well and come back with measurements for us, after it vents to parking height. Try to get both sides around 27 1/2"
Turn off air ride before adjustments and back on after they have been made.
I was thinking that just seems odd that both on the DS would go bad. Is there a way to "reset" the control box for the air ride. Maybe that could help, Idk I just sure the bags aren't shot.
there are 2 height sensors up front. these, i assume, do the left and right leveling.
then 1 in the rear to bring up the rear to match the front. so only 1 has to go bad or be out of position to skew the leveling ability.
no. it resets and re-levels every time you start the car and constantly as you drive.
adjust your height sensors and see what happens.
Check height sensors in the front. Let us know what each side measures.
what he said.
Nobody bothers to introduce themselves any more. Where has the common curtesy gone in the world.
Hey, heres my problem. Fix it for me. kthnxbai
Hey pearl, you wouldnt also happen to own a little 4 door Benz too would ya?
A nope can't say that I do, maybe the friend I bought it from did. He told me to use this website to find answers to problems with the car. I'm not that big of a car person so I'm learning as I go.
I hope he warned you not to threaten to shoot people in the face with a shotgun on here. That dude was a total douche and his Benz is a major POS.
Depends on if you know him or not, he was actually a good friend of mine but he moved home because he got out of the army. Which would be why I have the car now. And I remember hearing about that little thread, I guess its just the "your car my car war", and certain things you just don't say over the internet(what he said and whatever reason he said it). Either way its not my place, I'm just here to learn what I can about my new car.
