Mark Parts For Sale
topher5150
Grand Rapids, Michigan
these parts are for a 97-98 gen II Mark VIII
-two intakes (upper and lower)
-throttle body
-EGR tube
-engine wiring harness
-cylinder heads with valves cams etc
-Blizzak snow tires with rims
-front brake calipers and brackets
-under intake coolant hoses
-3.27 gears with open carrier
-fly wheel
-engine mounts
-exhaust manifolds (left and right)
-emissions assembly ( the one that runs from the exhaust manifolds to the front of the engine, with pump and bracket)
-Power steering bracket
-crank pulleys
-timing chain cover
- timing chain guides
-crank shaft
-oil pickup tube
