thaywood
Okay, I just got around to starting my "project". This is an idea I had recently for a new front air spring/shock design that has a separately removable air spring and shock unit. With this design, the air spring or shock can be replaced independently without having to buy the entire unit. If you need a new shock, but the air spring is still good, you can just replace the shock. And if the air spring leaks but the shock is still good, you just repalce the spring. I think that in the long run, this design could save owners a lot of money. And it wouldn't be exclusive to the Mark VIII. Companies like BMW, Mercedes, Land Rover, Jaguar, and many others use air spring/shock designs similar to the Mark VIII's. And in most cases, the air spring will outlast the shock absorber. And it would also make it a lot easier to upgrade to stiffer shocks if you want to instead of being restricted to whatever type of shock the manufacture puts in the unit. Here's a rough sketch of my idea. I just want to get some input and opinions. Thanks.
