Big Mike
Hello,
I have a problem with my brakes. Yesterday afternoon I started experiencing a very soft pedal, to stop the car I have to pump the brakes or mash them to the floor. This started after using the cruise on the highway and using the brake to deactivate it. After I did, the cruise would not work again.
When I first realized there was a problem was when I couldn't shift out of park, and the brake lights weren't working. I found out fuse 11 would blow immediately when replaced. I found the recall CC deactivation switch under the passenger fender liner and unplugged it as it has the recall open still. The soft pedal and weak brakes started before I unplugged it. When I unplugged the harness brake fluid poured out, approx. an ounce or so. The brake lights now work and fuse 11 is fine, as well as the shift interlock.
I realized the PO removed the ABS light from the info center, I replaced it and jumped the ABS test connector under the hood. I found a code 17 via the ABS self diagnostic. This code pertains to "17 Reference Voltage (Traction Assist code - Mark VIII only)" and my car has no traction control. I am lost there. I don't care about ABS function right now.
I need to figure out a few things:
Why is my pedal soft and weak? Is it the leak at the switch under the fender liner?
Where can I get a new Switch to replace the one that is on the car?
Advice and suggestions would be great.
