one piece driveshaft
sorry to hear about the fire:( That sucks! I must have missed the posts but how did that happen?
My stupidity. My 94 was bogging out on me after it would get warmed up and started when coming to a coast. I swapped out everything I could think of and I had a 93 engine in the garage just setting there. I decided to swap out 4 injectors on the drivers side. What I didn't know at the time (because I rushed it) was that one of them had two O-rings on it, maybe two of them did, not really sure but I put them in and bolted the fuel rail down, made sure everything was good and tight.
I should have primed the rail to get pressure up to it but instead, I just shut the hood thinking it would run fine. First try, it didn't crank. 2nd try, it sputtered and then finally it started. It was missing real bad now. I figured it was because the fuel rail just needed to build pressure. Well, it couldn't build pressure because one or two of the injectors were leaking gas while it was running. I had no clue and luckily I was inside the car with the windows up. This was in Jan, so it was cold out but I had the garage door open. I gassed it up to around 2K rpm for about 7 to 10 seconds and it was still missing real bad. I let off and it was still missing so I decided to just leave it alone for the night. It was 11:00 pm and I was sick of messing with it.
I pressed the door opened to close the door and when it got half way down, I reached to turn the car off and that's when the explosion happened. If I would have had the windows down, I would have been burned bad and if anyone would have been in the garage just standing around, they would have been killed instantly, if not burned extremely bad. Luckily none of the above happened. After the initial blast that blew the garage door windows across the street and blew out the side window and people 10 houses away could hear it, I jumped out onto a burning floor. It caught my pants leg on fire and then I dove out onto the driveway and didn't know it at the time but I gashed my leg on glass. Noticed that about an hour after the fact.
So, needless to say, I don't mess with injectors anymore and never will. I learned and I know I could do them correctly now but unless you have been in an explosion like that, it's hard to understand. I even blew the back wall of the garage 8 inches off of a concrete foundation. I did not get one burn on me, just the cut but the 94 burned in the front. I saved the black interior which was all good except for one door panel but I had another set luckily. After Jamie found out what happened, he offered me the 95 so I flew down to Florida and bought it and drove it back. I sent him a brand new compressor in the mail so that it would be there before me and he installed it for me. My liability insurance paid for the garage but everything burned in the garage, including the car was a complete loss and then another 2K out of my pocket for another car.
It took OMNI insurance months and months of investigation and jerking off before they would fix the house but they finally did after 7 to 8 months and now it's all back to new again. My dad had it cluttered out there and that's something that I don't believe in but a lot of it was his stuff that was burned. Some of it was mine but all I was worried about was my car. It was gone. No fixing that! A few pics below to show just what can happen when you rush things and don't check for leaks.
Ok, now I go to Florida to buy the white opalescent from Jamie.
It looked good inside but not my color choice but for the deal, I had to get it because I knew what I could do with it.
This was after I had the windows tinted and put new tires on it all the way around.
Next step was buying NIB headlight housings and a NIB grille. Another $700 just for that but that's what I wanted. The housings that Jamie had in there were fine and it was a set he had re-chromes but I'm funny about things and wanted new ones.
Grille and housings now installed with HID kits in the lows and highs. Now I want my black interior in the car but I don't want to mess with the dash. Decided to go with a two tone grey and black look to see what it would look like.
Started stripping it out.
Piled all the junk in the burned up garage lol.
Rear black deck panel and rear seats and seat belts went in first and carpet of course.
Now I'm getting the front seats in and coming up with this look so far.
Something still isn't hitting my eye right but I can't figure out what it is until I go check the other car and then I decided to remove the grey carpet from the side of the console and put my black carpet on that and it changed the looks completely.
Shortly after this, within a week, I put in the black door panels to finish it up all the way. I still haven't taken a pic of that yet but not hard to imagine. It also made a world of difference. Tonight I just bought two black sun visors and now I just need to do the headliner. I couldn't use the 94 because it had the moonroof, which I never used and never really liked it.
Next thing coming within the week will the be the stereo system I had in the 94 except now I have a new Kenwood eXcelon deck and all new wiring from front to back. I'll have the same setup as I had in the 94 which looks like this.
Three 10" JL Audio subs in a slot ported box designed for these 10's. I will be going back with blue hidden LED lighting so when the trunk is opened, the lighting will come on automatically.
The amps are Kicker Impulse. One is a 2252xi and the other is a 654xi and I also have a bridge that goes in between both amps to cover some wiring. That's what makes it look so long.
Now, the new home for the 95 is here. Before sheet rock was put up.
This is after the sheet rock was put up and insulation went up on all walls. Garage is fully insulated now. This is before it was painted.
Now completed with paint on the walls and the floor completely painted and that damn Sanoma was sold last week and is no longer sharing rooms with the Mark.
Now the Mark sets dead center and this concludes my story of what happened from start to finish. Now I need a black headliner lol. I could take it and get it done but I'm not leaving my car with anyone. If they can do it, I can do it. I just need to find the material and I'll do it myself for probably $100 less. I'm within one month of being done and then maybe wheels will be the next option but no rush for them right now.
To top all of this off, my dad passed away in his room in this very same house on July 8th and he never got to see the garage even being worked on. He was 62 and me and him and my 8 year old son had all lived together since 2004. 2010 was and has not been one of the best years and not just me but for many others on here.
Looks good Terry! When are you going to get your octastars back?
I don't know. I think I am going to go hunt their ass down. I know about where they are and shouldn't be hard to find when I stop at a country store or two and describe the truck and trailer that picked up both cars. I told them not to rush but it's been long enough. They also have my 98 trans with 60K on it that I J-Modded and I need all of this stuff back. Not really but that was the deal. If I get the trans back, I'll have something good to fall back on if the 95 ever acts up but so far, I couldn't ask for a better Gen 1 trans. No shudder or anything. Shifts out good and acts like it has many miles of life left on it. I still want my 98 trans. I got that thing for $250 and it worked perfect in the 94 and had a 2nd gear that I fell in love with. All gears were just THERE! No hesitation about anything. I have a near mint octi in my room to go along with the three they have. I'm not sure that I even want to put octi's on that car. Might go with 18's and be different. I take my time with things now lol.
We need to go find your rims and tranny. Where about are they from? I know alot of people! What kind of truck to they drive and what is their main business? Scrapping?
But yeah, I would take my time too if I had that above story to tell! Oh thats right I am anyways, look how long it is taking to get my car running! Oh and I am waiting on my ladie friend to get me that title on that other Silverfrost and I will be picking it up. It was about two weeks ago she sent off for it and they said it takes 4 to 8 weeks!
Oh yeah I have been meaning to tell you that I can paint your LSC mouldings whenever you are ready! I mentioned to you that I have my own paint and body shop! It has been taken over by a 79 chevy truck that I have been restoring but it is almost done!(this weekend) And I will have my shop back! I'll do them for free, just buy the paint!
They live out in the harvest area. They drive an older beat up Ford truck, brown and tan I think and they have a dual axle flatbed trailer. they scrap metal and just look like ole country hicks but are really very nice. I do want to go find them though before it's too late. Shouldn't be hard to come across them. Country stores out there know all and will tell all. You know how they are out there. I'm sure these people are well known just because of who they are. Characters lol. One of them is an old man and he don't do anything but try to tell them how to load a car. They had hell with the 94. It was slammed in the front with engine weight and melted sh!t all hanging down in the front. If I can't find them, oh well. I'll just be on the lookout for another 98 or 99 trans and do the J-Mod on it and set it aside until it's needed. I would like to have my rims back too.
Man, I live close to TVR(Tennessee Valley Recycling) off of Holmes avenue! Whenever I drive by there, there is about thirty to fourty scrappers, which match the above description just different vehicles!!! lol I will spot them sooner or later and give them the message!!! This is a small town!!!
That would suck if they already scrapped my car. I don't care what they do with the 93 but they said they were gonna get the engine out of the 94 and then flip it upside down and get the trans out. I'll keep an eye out on CL for another trans. That's how I found that one. A guy bought the engine and trans for a project but only needed the engine. It was from a 98 and he sold me the trans, PCM, shifter and brought it to me for $250. I jumped all over that.
Holy Shizznit man! Thats the craziest car repair mishap i have ever heard! I cant believe it did that much damage to the garage. I would have pooped right in my pants.
Im wicked sorry to hear about your pops bro. Dont worry though things will start to look up for ya it cant stay bad for too long.
I love the 8 though. That two tone interior is wicked cool! Same with the sub install nice and clean! I'd like to see pics with the door panels in.
Oh yeah, It is really clean in person! Jamie did him really good on that deal! I know they did'nt come with the car but I could'nt get over how good the grill and headlights looked like! Makes it look like a brand new car!!!
i think i've been inspired! On my current 97 project it has all grey interior and i have a complete black interior so im gonna do the same two tone. thanks no limit!
Can't wait to see it and have patience. That is a damn job, if you do it alone like I did. IMO, black and grey just go together perfectly. I'm still in the middle of day three on the stereo install and have to remove the door panels to pull out the old and replace with the new and new wiring through the rubber tube. When I get everything back together, I'll take a pic with the door panels in. It does look better with them in than what you're seeing in the pic. This stereo install is beating me down because it's a complete re-wire from nose to ass. I'm extremely anal about wires showing, so yeah, a lot of the interior is out right now but that's the easy part.
I can't wait to see a Gen 2 with the black / grey blend with a hint of woodgrain. One of the main things that's going to make a difference with the eye is gonna be the console. Gen 2's have more of a straight look and not as much curvature to pull off the cockpit look. I'll check out some grey interiors and see what could be done to pull off a good look.
