I was previously having a problem with the transmission leaking so I had the seals replaced. I am also having a vibration above 60mph issue so I've had the tires re-balanced and the axle and u-joints looked at.
The mechanic said the u-joints looked good and didn't need replacing. He also took another look at the tires and said that NTW had put on a heck of a lot of weights ( 3 grams on one of the tires ) and that the issue is most likely that.
I thought when I had the oil changed that they had messed up the filter gasket so I brought it back to the same shop. ( these guys did the seals on the transmission also ). I got under the car and saw that the transmission is leaking badly where the driveshaft goes into the transmission. There is also a slight leak where the transmission meats the bell housing it appears.
edit: I also reached up and tried to wiggle the driveshaft and it didnt' wiggle. I tried rotating it and it would rotate about 1/4 of an inch. Don't know if that's significant but I thought I'd tell you guys.
The mechanic said if I brought him the u-joints tomorrow he would do the work for free. YAY But, I don't think the u-joints specifically are the problem. I think it is the part where the driveshaft attaches to the transmission. Is this a part I can buy? If so where and what is it called.
Thanks again guys.
btw: I have a 97 and these came with 2 piece driveshafts. How are these things designed. 2 piece as in one piece inside another or 2 pieces as in two different segments? I didn't see 2 segments but I didn't get a good look under the gas tank.
Thanks again guys.
